This is new work. It is leaking at 2 places, at the spigot and at the shutoff valve. Wondering the best foolproof way to try this again and this time with no leaks.
This is for a sprinkler system.
Upper leak is where the brass spigot is connected to a short iron nipple which is screwed into the plastic female fitting. Teflon tape was used. The glue joint is good. A plastic spigot, with all glued joints, would be fine, if that is the best way to go.
The lower leak is where the female threads of the brass valve attach to the male threads of the plastic fitting. Teflon tape was used. I originally had a plastic shutoff valve here, glued to plastic pipe. This worked fine until the valve broke and I wanted to replace that connection with a better valve. So I went to brass. Maybe this would work OK but is just not tightened well enough. I also used teflon tape and maybe that was a mistake.
Lower connection on the shutoff valve, brass-to-plastic, is not leaking.
You need to use a generous amount of TFE paste on the threads, not just Teflon. (Any sealant like Rectorseal T plus 2 will work) And you need to be very careful tightening brass into PVC (or vis versa) because if you get it too tight it will crack the PVC.
Hi Gurus,
I am trying to remove the stem as there is a drip. I can remove silver metal washer seen in attached photo but there a rubber er seal/washer behind it that i cannot remove easily, I tried removing it gently but was not successful, If i poke with something I am afraid I will damage it.
My question is how do proceed further from here ? I tried pulling the stem and also rotating it with pliers in case it is threaded!!!
Please advise.
Thanks.
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_7225_e32aaa058729001abbeacefd37bde80144ce4b93.jpg[/img]
I bought a new bathtub and had it professionally installed only to find out that the popup drain does not stay down - it clicks when pressed but then pops right back up to the same level as before. I got a replacement popup drain from the bathtub manufacturer and tried replacing just the top part (in the attached picture), but the new one has the same problem as before. At this point, I do not want to get yet another shipment from the manufacturer, as my house is on the market and I need to address this as soon as possible. Is there a way to try to fix this issue without having to replace the entire drain?
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210506_175244_fb45b10b247eb2ddb14d7400cc2c3a3a65a0e5a6.jpg[/img]
