Pex Tubing Memory
Old 05-30-21, 04:39 PM
W
Received 60 Upvotes on 52 Posts
Pex Tubing Memory
I am about to start a re-piping project in our house. I would prefer to use the pex in rolls rather than sticks of pex. How do I remove the memory in the rolls so that the runs will be straight?
Old 05-30-21, 04:49 PM
XSleeper's Avatar
Received 1,714 Upvotes on 1,538 Posts
You don't... you use hold down clamps to keep it straight. And the way you uncoil it by unrolling helps avoid kinks.
Old 05-31-21, 03:48 AM
P
Received 1,768 Upvotes on 1,581 Posts
Temperature makes a big difference. Warm pipe is much easier to sorta straighten and is much easier to work with to the point that it's not really an issue. During winter a frozen coil of pipe can become a bit of a wrestling match at times.
Old 05-31-21, 04:53 AM
B
Received 235 Upvotes on 208 Posts
Old 05-31-21, 06:33 AM
O
Received 8 Upvotes on 7 Posts
I stretched out a 25 foot roll of 1/2" pex by sticking each end into something that would not allow it to recoil back. Left it for a couple of hours and it took a lot of the recoil out of it. Nothing perfect but it made it a little easier to work with.
Old 06-02-21, 02:33 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
Pex pipe will never be nice, neat and perfectly straight, that's just the nature of the product. As was mentioned, use hold down clamps to keep it straight as possible.
