Set screw on backflow preventer
Old 06-10-21, 09:19 AM
W
Received 1 Upvote on 1 Post
What is the purpose of the set screw on the backflow preventer I'm using on my hose bib? The backflow preventer is screwed on securely and seems to be working ok, but I haven't tightened the set screw yet.
Top Answer
06-10-21, 03:15 PM
Pilot Dane
Pilot Dane is offline
Received 2,228 Upvotes on 1,988 Posts
Local building codes can't dictate what manufacturers produce. But, manufacturers will produce what people buy. And, because people buy non-approved hose bibs someone manufactures an add on check valve so you don't have to throw your non-approved sillcock into the recycling bin.
Old 06-10-21, 09:56 AM
2
Received 394 Upvotes on 343 Posts
The set screw is there for code reasons to make the back flow preventer non-removable. The screw is tightened until it breaks off and then cannot be removed.
A couple of years ago I installed a separate meter for outside watering and was required to add back flow preventers to all outside spigots. Fortunately the installer did not use the screw on the drain spigot for the underground sprinkler system so I can remove it when connecting a compressor to blow out the lines for winter.
Old 06-10-21, 10:55 AM
W
Thank you for the reply!
Just curious, if code is so adamant about have permanent backflow preventers on hose bibs, why not require manufacturers of hose bibs to build them into their product?
Old 06-10-21, 03:15 PM
P
2john02458, Zorfdt voted this post useful.
Old 06-12-21, 09:56 AM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
Many do ........................................
Old 06-13-21, 09:55 AM
W
I haven't seen them at Home Depot. And why not include them when purchasing a new hose?
BTW, what is so toxic about the water in a hose? We used to drink from hoses when I was a kid.
