ASME B16.3 Thread Allowance
Hi All,
I'm running some 1/2" and 3/4" black pipe. I need to cut and thread some very accurate sections. According to some information I dug up on how to calculate pipe lengths, I need to know the thread engagement of the fittings. I was able to find the face-to-center dimensions. So I don't need those.
Anyone know these figures off hand?
Thanks in advance!
Thanks in advance!
Possibly an American fitting.... if you could find one.
By the nature of how tapered threads work, there will never be a precise measurement on thread depth, since it's reliant on both the male and female cut threads.
But this should get you close:
https://www.engineeringtoolbox.com/n...ads-d_750.html
Specifically, Approximate Total thread makeup (inches)
For 1/2" pipe, the thread should seat 7/16"
For 3/4" pipe, the thread should seat 1/2"
If this is for a plumbing/gas installation, you're probably laying something out less than optimally to require a precise cut.
I see 6 tolerances here. 1 and 2 are the tolerances the end pieces the new pipe will connect to. 3 is the tolerance of the thread die to cut the threads in the new pipe. 4 and 5 are the tolerance of the OD and ID of the new pipe. 6 is the tolerance on the torque the connections are tightened to. I think fitting by trial is much easier than coming up with measurements for a tolerance calculation. Good luck.
PJmax
voted this post useful.
