I’m trying to replace my kitchen sprayer due to leaking. The end piece WILL NOT come off. The piece that connects under the sink won’t come off. I just went to Home Depot and they couldn’t find anything that would work. I’m attaching pics. I’ve tried adjustable pliers, wrench and needle nose
It looks like it has at least one disconnect tab. There may be a second one on the other side.
You'd put a screwdriver where the red line is and carefully unlock the clip.
There is no brand name anywhere on the fixtures. I thought I needed to press in on the tabs and pull down but it won’t move. I had a friend over and they couldn’t get it either
Hi All,
I'm running some 1/2" and 3/4" black pipe. I need to cut and thread some very accurate sections. According to some information I dug up on how to calculate pipe lengths, I need to know the thread engagement of the fittings. I was able to find the face-to-center dimensions. So I don't need those.
Anyone know these figures off hand?
Thanks in advance!
Does this sink Tee look like it’s sideways? If the stack is supposed to be in the wall I would think it would be facing away from me in the picture. You can see the toilet rough in for reference where the wall should be. Thanks!
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/85fb122f_c611_42f9_b814_4117d65922ca_6480b250f8bc5c5b1f565642d724184ae748f2f5.jpeg[/img]
