barbed adapter compression fitting?
Old 08-14-21, 11:23 AM
H
Hello, I have to connect 1/4" low pressure poly tubing to an air supply outlet using this barbed compression adapter fitting. Please see the photos.
My two questions are: Do I need any gasket to go between the barbed adapter and the nut or it is just metal to metal compression? Why are there two pieces, can I replace these two parts with a one-piece fitting?
Would appreciate any comment and suggestion! Thank you and Best Regards to All,
harum.
Old 08-14-21, 06:05 PM
H
Thank you XSleeper! There is no inner thread in the adapters in your links... I would still need to thread the barbed adapter onto the low pressure outlet. Still unclear if I need to use a washer between the two parts in the first two photos.
Old 08-16-21, 10:21 AM
H
Was wondering how many turns do I turn the nut to provide an air-tight compression of the barbed adapter? I could only do one and a half turns with hand tightening and the barbed adapter is still loose. Is a washer or a ferrule missing in this connection? Thanks!
Old 08-16-21, 02:16 PM
Z
Received 91 Upvotes on 84 Posts
harum-
I don’t know but my guess is that if inside the fitting at B, is shaped the same as part A, then I bet it’s like a flare fitting. The nut just gets tightened up and A makes an air tight or liquid tight connection into B. Nothing else is used - except I guess Teflon tape wouldn’t hurt on the threads to help tighten. But I’m just guessing.
Doesn’t look like there are a lot of examples around using that type of connection. Wonder why. Maybe one of the plumbing guys would know. If it’s for air couldn’t you just try it - or would that hurt the equipment? Doesn’t seem like it would.
Norm201 voted this post useful.
Old 08-16-21, 03:45 PM
Norm201's Avatar
Received 663 Upvotes on 586 Posts
Zoesdad is correct it's barbed adapter flare fitting, not a compression fitting. Do a google search in images. Lots f examples. No gasket or washer is needed.
