My bathroom sink is making very loud banging sound when running hot water. The cold water pipe/faucet is fine though. It doesn't seem to matter whether I open the hot water faucet fast or slow, it'll make this banging noise. It seems the banging noise is random but one thing I'm certain is that the noise does not occur when the water is cold on the hot side faucet. Any help is much appreciated.
Could be air trapped air in the pipe. But that will usually purge itself. If you have access to the bare pipes, running the hot water, grab the pipe and feel for vibration and if holding tight eliminates it then securing it will resolve the problem.
How close is this particular faucet to the hot water tank? Is the pipe touching any other item such as other piping, or ductwork or even a rafter or stud without being clamped to it?
Thanks for the response. Actually when the hammering starts, the water flowing through the faucet is actually slows down. So, it's not only is the noise from the pipe but the flow of the water is slow down significantly. This noise just starts about 2-3 months ago. When we first purchased the house, we've never experienced it.
That could be a sign of a faulty faucet washer, stem, or cartridge. What brand is the faucet? How old is it? You might want to upgrade to a Moen or Delta.
I agree with Norm. Usually that jackhammering noise is the result of a worn or loose washer somewhere near the fixture you're using. Could be in the faucet itself, or the stop under the sink. Could be elsewhere too, but it would then likely affect other fixtures also.
In most cases, it happens when the water flow is less than full-open... but can happen anytime.
One way to test would be to close the under-sink stop by a turn or so and see if that changes anything. Might get better or worse, but the change will help narrow it down. Then, depending on the valve or faucet, it can either be a washer replacement, or a valve/faucet replacement.
Thanks, everyone! I'll give that suggestion a try tonight. It is a Moen brand and I've purchased it about 3-4 years ago. However, it was one of those discontinue product line from Moen when I purchased it. I wanted to match my other bathroom.
Okay, I finally got the time to remove the hot side handle and this is what it looks like. I don't see anything wrong with it. If I slowly turn this plastic red thing here by hand, it'll make the hammering/banging sound as well. Other suggestions?
Your dealing with tolerances that you can't see. Call Delta (or is it MOEN) and get a replacement cartridge. It should be free or buy one at the local home improvement store.
One additional thing I did was, while it's making the banging noise with the handle turn wide open and water flowing, I slowly turn the valve of the water supply off. As soon as the water is off while the handle is still wide open, there is no banging noise but as soon I as slowly turn the value of the water supply line back on, the banging noise comes back. Any idea where the cause may be at? Thanks!
Yes. The shut-off valve. What I call the isolation valve. You might be able to fix it rather than replace it. Depends if a cheapy or an older repairable type. You'll need to turn off the water main for the whole house.
Edit...not the supply line itself, but you can if you want.
By how much do you need to turn that valve off? By throttling back can you still get good flow? If it's only a little bit, you can cheat and let it go for awhile.
You'll need to find out if that valve is soldered on or screwed on. And how much of the copper pipe sticks out from the wall. They look like cheapy ones not repairable. But I'm not sure from the pic.
Since the shutoff value is readily available at my home center, I'll replace that first. If the noise continues, I will try to get a replacement from Moen.
edit...when you shut off the water to the whole house, be sure to open a faucet to relieve pressure and drain the lines. Open the lowest and the highest.
I can tell a lot of DIY work was done in the home I'm in at the moment and much of it was not good work. The lower level bathroom is one of the things I believe to have been homeowner designed and built and the sink has never drained well. The plumbing is hidden in the walls but I'm suspecting there is no air vent - is there a way to determine this without tearing out sheetrock?
Have a shower head to install but the curved pipe from the wall doesn’t bottom out the threads until the shower pipe is 90 degrees to the left (9 o’clock).
it sprays water par the threads.
will Teflon tape or plumbers putty fix this so the shower pipe is at 6 o’clock?
