adding air to pressure tank
Old 06-26-01, 05:11 AM
D
What is the proper procedure for adding air to a pressure tank. For example, do I leave faucets open or closed? Pump on or off? By the way, I don't have shut off valves either right before or after right after the tank, so I hope these are not needed.
Thanks!
Old 06-26-01, 05:21 AM
Guest
hi dave
you may want to check this website for some tips.
http://www.davey.com.au/supercelltips.html
good luck!
Old 06-26-01, 05:39 AM
Mike Swearingen's Avatar
Cool
Turn the pump power OFF (pressure tank does not have to be valved off), and if you have an air bladder-type pressure tank, just add air with a bicycle pump or portable air tank or compressor.
It should be two PSI below your cut-on pressure.
Check the tank pressure with a tire gauge.
