Minimum height of sink outflow pipe relative to p-trap outflow pipe
I want to replace my old top-mount sink with an undermount sink, which would result in the outflow pipe from the garbage disposal being only 1.25 inches above the outflow of the P-trap. I've read that the p-trap should be no more than 24" below the outflow from the garbage disposal, but there is no minimum distance. Will water have trouble flowing out of the garbage disposal if the p-trap outflow is only 1.25" below the garbage disposal outflow? Thank you.
I had a similar problem. I increased the length of the pipe coming down from the disposer.
This results in a deeper than normal trap retention area.
I allow more flushing after using disposer to make sure trap is clean.
I have an old house and there was no way to mess with the iron pipe in the wall.
One day I may run a new drain line down. The hard part is picking up the vent.
Hi Everyone:
I do not know very much about plumbing and would appreciate any advice.
I cannot remove my broken-handle valve from the cutout wall for the refrigerator water line.
Spraying with some lubricant over night did not help.
Is there any special thin wrench to loosen the thin hex nut between the valve and the box?
A thick wrench will not get in between.
How do I know the valve was not soldered to the pipe? I do not want to break anything behind the wall.
Should I let a pro plumber do this job?
For now, I put an end-cap to block the water flow (where the clear tube shown).
Is it safe to leave the way it is?
I am considering do not even hook up the water line to the refrigerator, if this is too much hassle.
Please see pictures attached.
Thanks
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210825_132811_55daec629629a1eceacf205c519dbc3bd1fedf5b.jpg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210825_133637_3924a40e2b5feebb87496e50008a5c72dd622c8f.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210826_135312_7bfd3dde969423ee05d2b284e28916cc222482bb.jpg[/img]
Hi,
This is my first post.
I am adding new bathroom in the basement. I gave the work to a contractor. The new bathroom pipes needs to be connected to the sewer line. After digging the foundation, the contractor notified that there is a crack in sewer line (cast iron) on the upper side of the pipe. I can see the crack but there is no visible leakage. He is asking for additional $4000 to replace the sewer pipe which is 30 to 40 feet long under the foundation.
I live in NJ.
What is the best approach? Is the amount reasonable. Are there better options
Any advise will be helpful.
Thank you
