high water pressure low volume
Old 06-26-01, 01:54 PM
Guest
I built a house about a year or so ago. My problem is that I get low water volume even though my pressure is about 56 psi. I have copper pipe throughout (3/4 main and 1/2 supply). I have no idea what is causing this.
Old 06-26-01, 04:47 PM
Mike Swearingen's Avatar
Cool
dan,
Make sure that all valves (from Main to individual fixture cut-offs) are wide open and clean out all faucet aerators and showerheads, and see if that doesn't help solve the problem.
If it doesn't, just come back on this thread, and we'll try to help you.
Good Luck!
Old 06-27-01, 02:19 PM
Guest
All my valves are wide open and aerators/heads have been cleaned out with the same results.
Old 06-27-01, 05:31 PM
Cool
Are you on a well or public water supply?
Old 06-27-01, 08:24 PM
plumbguy
do u have 56 psi before the prv or after?
