Basement Bathroom and repurpose pit questions
Old 11-19-21, 08:48 AM
I
hello everyone.. i have a unique situation, and would like to know the best way to approach this without spending a ton of money or opening walls above.
i have an existing floor drain in the basement, that goes into a pit, and discharges to the main stack.
this has a 1-1/2" out and 1-1/2" vent that goes straight to roof. (maybe it switches to 2" somewhere, but from the basement and up into the 1st floor, its 1-1/2".)
anyway, i will convert the 1-1/2" to 2" for discharge, but i want to leave the 1-1/2" vent alone. here is a diagram of what i want to do, and see if this will work, or do i need to add more vents, or any other suggestions are very very appreciated. thank you in advance.
Old 11-19-21, 08:54 AM
I
Plan View
Old 11-19-21, 09:10 AM
P
Received 1,768 Upvotes on 1,581 Posts
I am slightly confused. Do you only have a floor drain and sump now and want to add a bathroom discharging into the floor drain's sump pit?
Old 11-19-21, 09:46 AM
Z
Received 367 Upvotes on 327 Posts
When planning a basement bathroom you have pretty much two options for the pump. One is a traditional pit with a macerating pump. You'll probably need to dig out and swap out the pit liner you have now since if it's for storm water it won't be sealed correctly for sewage.
Sometimes a Saniflo type system is easier since it doesn't have to be buried. Plus the plumbing requirements are simpler.
Another reason to go Saniflo is that it requires only a 1.5" vent. A sewage ejector pit/pump requires a 2" vent as you're still venting the toilet per standard codes.
Old 11-22-21, 07:35 AM
I
so to clarify:
I have an existing floor drain, that goes into existing pit, that has a regular pump in there, 1-1/2" vent and 1-1/2" discharge into 2" that goes into main stack. this is separate from my existing sump pit that discharges outside.
i want to pull out the pit, put in proper ejector pit, and ejector pump.. convert 1-1/2" discharge into 2" discharge, but leave the 1-1/2" vent to the roof. since im not sure i have access to this 1-1/2 on the 1st and 2nd floor, to either check if its changes to 2" above, or is 1-1/2" all the way to the roof.
Old 11-22-21, 08:18 AM
P
This article describes the vent size needed for a sump pit.
Old 11-23-21, 06:27 AM
I
Developed length included everything? even up to the roof?
ive read online, that the pit must have its own dedicated vent, up to the roof? but then, i've seen and read online that its combined with bathroom fixture vents as well.. its all very confusing... was looking for advice and how to do it in a way that i wont have issues in the future when selling...
Old 11-23-21, 07:47 AM
P
Yes, the total length of the vent from your pit in the basement all the way to where it ends above the roof. The reason is the walls of the pipe create resistance to airflow. Longer, smaller pipe can't move air as well as shorter or larger pipe.
