Water hammer arrestors throughout the house
Old 12-01-21, 07:40 AM
O
Received 2 Upvotes on 2 Posts
I hear some tapping when using some of the plumbing in the master bedroom and guest bath which are both on the second floor. I'm wondering if it's prudent to install arrestors there. Mind you it's not a rapid tapping like you'd think, but rather it's a steady tapping that decreases in tempo and stops within 20 seconds.
Top Answer
12-01-21, 08:28 AM
Pilot Dane
Pilot Dane is offline
Received 1,766 Upvotes on 1,579 Posts
A tapping sound like you describe is usually the pipes expanding and contracting with change in temperature. Something a water hammer arrestor will not help with.
Water hammer occurs when a valve is closed very quickly and is only one "thunk". It most often happens with appliances like clothes and dishwasher but can happen if you have single handle faucets and slam them shut quickly.
Old 12-01-21, 08:28 AM
P
2john02458, joecaption, Zorfdt voted this post useful.
Old 12-01-21, 08:50 AM
2
Received 319 Upvotes on 273 Posts
This is especially noticeable with PVC pipes.
Old 12-02-21, 01:10 PM
O
This was a series of thunks that happened behind the dishwasher. It was like the drums in a death metal song. But now it's been "arrested."
​​​​​​​A tapping sound like you describe is usually the pipes expanding and contracting with change in temperature. Something a water hammer arrestor will not help with.
I'll say that this happens at the beginning of mid to late fall and ends towards the end of spring. Maybe that's coinciding with the change in temperature like you mention? What's my option if an arrestor won't work?
Old 12-02-21, 01:31 PM
Received 3,422 Upvotes on 3,068 Posts
If you know the area of the wall where the banging is occurring.... you can make a small hole and spray in some minimally expanding spray foam.
Don't use the regular expanding foam as it can blow the wall out.
I have done this and it does work.
I also use the same foam to hold electrical boxes in the wall when the hole is too big.
Works great for the pipe that comes out of the wall for a shower head and is flopping all over the place.
Old 12-02-21, 01:37 PM
O
I know it's in the bathroom but can't really pinpoint it. I know that stuff echoes. What can I use to discover where the pipes are?
