CPVC Glue Dry Time
Old 12-18-21, 07:29 AM
W
Received 60 Upvotes on 52 Posts
CPVC Glue Dry Time
What is the minimum dry time for orange CPVC glue on cpvc fittings?
Using purple primer and pipe is 3/4 inch cpvc.
(First word in title should be CPVC)
Top Answer
12-18-21, 09:46 AM
XSleeper's Avatar
XSleeper
XSleeper is offline
Received 1,701 Upvotes on 1,525 Posts
Old 12-18-21, 08:37 AM
P
Received 1,759 Upvotes on 1,572 Posts
At normal house temperatures you could get away with 15+ min but I would give it two hours if you can before turning the water back on. If this is in a cold space allow more time.
Old 12-18-21, 09:32 AM
Received 740 Upvotes on 646 Posts
It depends, I usually buy the all purpose glue which dries like PD stated but unless I'm mistaken the CPVC only glue takes a lot longer before it can be put in use. It always states on the can how long before you can put pressure on the line.
Old 12-18-21, 09:46 AM
XSleeper's Avatar
CasualJoe, marksr voted this post useful.
Old 12-18-21, 11:50 AM
W
Thanks for the help.
