Need advice on moving powder room sink pipes 4 feet to another wall
Old 01-03-22, 12:40 PM
R
I am getting ready to remodel my powder room. I would like to move the location of my sink 4 feet to another wall to free up some space. Before I start removing some drywall I wanted to ask how hard this job would probably be and what steps I probably need to take. I enclosed a picture of the sink and the wall where the mirror is shown is where I want to relocate the plumbing. Thanks in advance.
I would like to relocate this sink under where the mirror is on the next wall.
Old 01-03-22, 01:08 PM
P
Received 1,769 Upvotes on 1,582 Posts
Is the mirror wall (new sink location) an interior or exterior wall? If it is an interior wall your project is a possibility. If it is the home's exterior wall I would not put the sink there if you have freezing weather in winter.
It is not rocket science and a change like that is relatively straightforward. Unfortunately the devil is in the details and you really need to open the walls to see what your getting into. The water supply lines are the easiest to relocate and should pose no problem. The drain line is usually the difficult part since the pipe is larger in size and must have the required fall and be within distance of a vent.
Old 01-03-22, 01:16 PM
R
It's a interior wall. I will open the wall and post back
Old 01-03-22, 02:16 PM
XSleeper's Avatar
Received 1,718 Upvotes on 1,542 Posts
It's also helpful to have access below and access above which makes it easier to replumb in a new location. If there is no access above or below in an attic or basement it makes it more difficult. And you never mentioned any of that. Once you open the walls, pics of what you find and a few from below would be helpful.
Old 01-03-22, 02:29 PM
Marq1's Avatar
Received 1,105 Upvotes on 1,005 Posts
A picture of the basement (assuming) would be more informative!
