Need a G1/2 female to 1/2 Male or appropriate adapter
So I purchased the following to try and reconnect my bidet:
https://www.amazon.com/dp/B01BTY5YRO
https://www.amazon.com/dp/B06XPRVGW6
Little did I know that a G1/2 connector is different than a 1/2 connector. Not sure if that's the case but can you recommend a different hose that will fit it and have a female 3/8" on the other side? Or even an adapter that will work.
Thanks!
Thanks!
You said "reconnect". Why can't you reuse the fitting that was there? If you want to replace the flex water supply hose it's a standard used on toilets and available at all home centers and plumbing suppliers.
If you are connecting a new bidet look through the hardware included with the bidet. Every one I've installed came with the "T" splitting fitting.
If looking for fittings in the US most people don't call it a G1 2. Most would call it a "1/2" straight thread" or "1/2" BSP".
Not sure that your local hardware store would carry it but there are G1/2 to 1/2NPT adapters available. The thread pitch is different hence the need for an adapter. Available on amazon for $8.
The braided line you show is for a typical balcock valve on a toilet. 7/8" You might be able to use the braided line for a faucet which is 1/2" NPT as the adapter you are looking for is 1/2". The braided line makes a seal using a rubber washer to the inside of the pipe, not thread to thread binding. As long as you can snug up the nut, it might work. I would try the braided line with a metal nut instead of the plastic nut.
