Once you have cleaned all of the old caulk from around the perimeter where it is clean and dry,then fill the tub with water,now caulk the tub.when it drys release the water this will give you a pre expanded joint that will not pull away.
Please Help!
My upstairs shower-bathtub enclosure leaks to downstairs celing when the shower is used. Is it a broken pipe or what else could it be?
Also how do I remove the enclosure to find the problem.
Read More
I have a shower and toilet on one wall and would like to put the sink on the opposite wall, which are seven feet apart. Is there a way to properly vent all three together?Read More
