I am sure there are some guys on here that know this. Could there be any reason why this copper water pipe has this loop in it?? Would like to remove it to install softener....
Also: we found a couple galvanized water pipes in a ceiling, assuming they have to be replaced??
Hi, I am trying to loosen the hose nut in my yard after four months by my wrench but it not rotating. If I try force too much by my wrench, then the pipe coming from the ground starts moving and I do not want to break those. I have highlighted the hose nut with red in picture. Any tricks to loosen or soften that?
Thanks in advance
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/img_4859_57f6705f248065892c6e5b0bf6b9b2c13e708a4b.jpg[/img]
I'm tackling a drainpipe leak in my crawl space and could use some guidance please!
Attached are pictures of the area from several angles. The leak is in the 1.5" just below the copper Y.
I don't know if it's just a failed solder, or copper that needs replacing. Everything in this house seems to have been done poorly originally (1978 build), so I'm inclined to assume both.
The copper above the Y goes through a concrete block wall, so I don't really have more than a 1/2" wiggle room at best to fit pipes together. Honestly since the Y is connected to a toilet directly above, there may be absolutely no wiggle room.
I'm assuming I need to replace everything from the threaded copper going into the cast iron up to the bottom side of the Y. But with so little wiggle room - how??
Thank you! Looking forward to the commentary on the work. Not my handiwork, so you won't hurt my feelings! ;-)
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20220210_124437_9b655d31874577f7f48c5079fe00f8e61867b3b1.jpg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20220210_124444_33f91fa9eeba027015f03243f02d275aa49924ed.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20220210_124455_a202867d46bc723d11d9d7001173d522d628b533.jpg[/img]
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20220210_124515_f43a8e886ce2431f6a42dc471d174feb428b3358.jpg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20220210_124532_3ff609185515f3f11cf7a0f87f3c849fd58b43ce.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20220210_124548_e60b4908e7b03c30882b88e1d64bf87fa94c3ef9.jpg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20220210_124602_fae0758ccba9cf01c4bc6a8f9c79ed69998c46cb.jpg[/img]
