Stuck shower handle / valve / cartridge
Old 02-23-22, 11:45 AM
B
Received 3 Upvotes on 3 Posts
This shower valve is stuck from not being used for the better part of last year. I thought to pull out the cartridge, apply silicone grease, re-install or replace if needed. There's hasn't been any leaks tho'. I have replaced moens 1222 etc but this looks different. There's no ID markings. I see similarities to Delta on UTube, but I am not sure. The handle turns just a wee bit, but it does slip and I will need to replace it anyway. I used a crescent wrench to rock it back and forth gently, but it's still about the same and I don't want to create bigger issues. Can the pros confirm from their experience if this is a delta and any tips or UT links on it's removal. Thanks.
Old 02-23-22, 02:19 PM
P
Received 1,776 Upvotes on 1,588 Posts
You mentioned using a Crescent wrench on the handle. Have you tried unscrewing the big hex (with the water turned off of course)?
Old 02-23-22, 07:39 PM
B
No I hadn't. I re-watched delta faucet removal and I see what I missed. I think I am fairly certain this is a delta. The only thing I did right was not to put any Mr Olympia-bound-muscles on anything. I will re-try per the videos and see how it goes.
Old 02-23-22, 08:03 PM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
Can't see the hot or cold markings on the trim... can't see the screw locations on the trim... can't see the entire handle in the pic, and can't see what the handle looked like before it was disassembled. Doesn't look like a Delta to me.
Old 02-23-22, 08:37 PM
B
Trim is marked hot/cold on left/right respectively. Single trim screw is at the bottom 6 o'clock position, angled to fasten into the ... neck?
Handle and round plastic wheel seem generic, not original but must have been updated at some point. There are no markings on them.
It's definitely not a moen, neck is too fat, and the moen puller doesn't fit nor is there anywhere for it to sink it's "feet" into.
The thick crome neck looks similar to what I saw on UT, you just pull it straight out towards you so you can have access to unscrew the big hex nut. Thus, I thought it must be a delta but you say no. What else could it be?
Old 02-23-22, 10:23 PM
XSleeper's Avatar
What else could it be? There's only several dozen brands.
Yours appears to be a Brasscraft.
Example of a replacement part. You would have to verify the size is a match.
https://www.amazon.com/88200-Cartrid...00DZFU5M&psc=1
Old 02-24-22, 04:43 AM
P
I agree. I have never seen a Delta with that handle style. But, many faucets are constructed similarly. The devil is in the details though as far as finding replacement parts. There are several clone brands that do interchange parts with their brand name equivalent.
Old 03-01-22, 07:18 AM
B
It was a Brasscraft. However, I decided to service it before the cartridges got here. Cleaned out soap scum gunk and re-applied silicone grease. The handle is now turning freely as it should. The new cartridge as a handy back up. Thanx guys.
