Spigot Repair Kit - Proper Length To Buy?
Old 02-23-22, 07:51 PM
B
Received 3 Upvotes on 3 Posts
Need to buy a hose bib repair kit. I am not sure how to determine what length is for this unit. The spigot itself lengthwise matches the HD - 6 in. Lead Free Anti-Siphon Frost Free Hydrant with Built-In Vacuum Breaker. But how do you determine the correct stem length for repair kit?
Old 02-23-22, 10:39 PM
XSleeper's Avatar
Received 1,710 Upvotes on 1,534 Posts
It appears you need a 6" repair kit. For $10 more I would just get a new spigot.
CasualJoe voted this post useful.
Old 02-24-22, 04:40 AM
P
Received 1,764 Upvotes on 1,577 Posts
I agree with XSleeper. I would replace the entire faucet if you cannot verify the manufacturer and model number of your spigot. Just because yours looks like one at HD doesn't mean the parts are interchangeable. Just getting a new one could save you some headache.
Old 02-24-22, 07:22 AM
B
Appreciated your input guys. Already got the 6" Arrowhead from HD, both have the same length. Haven't installed it yet as weather is nuts in N. Dallas right now.
However, i was wanting to repair the old unit for future emergency use or something, for reasonable. Thus my interest.
Old 02-24-22, 12:40 PM
Received 3,417 Upvotes on 3,064 Posts
I'm big on rebuilding but I've found the most common problem is the threads that are cast into the fitting strip. So when you replace the piece that turns.... it just spins too.
Old 03-05-22, 11:27 AM
B
Quick question - Is this EFIELD Sillcock code compliant, seeing that it doesn't have an anti siphon? If not, will adding a connection vacuum breaker bring it up to code?
Old 03-05-22, 12:56 PM
XSleeper's Avatar
AFAIK, as long as a hose is on a vacuum breaker that's all that matters.
bambata voted this post useful.
