broken tailpiece
Old 03-12-22, 06:49 AM
H
broken tailpiece
Hi there
The tailpiece of the bathroom tub broke off. How do I reattach it?
Looks like I need a new tailpiece. Is that a 1 1/4" threaded tailpiece? Do I need to untigthen the nut that is right under the sink and remove the piece of pipe that is above the arrow? Can I fit a pvc tailpiece to a chrome p trap?
Thanks
Old 03-12-22, 06:58 AM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
Looks to me like you need to replace the entire sink pop-up drain and then probably extend it with a 6" tailpiece or a 12" tailpiece that you cut to length. Yes, a pvc tailpiece will work with the chrome trap, you just need to use the same size. Either 1 1/2 or 1 1/4, whichever it is.
Old 03-12-22, 12:46 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
I would just go ahead and replace the chrome trap with a PVC trap at the same time.
Old 03-12-22, 03:40 PM
Received 3,419 Upvotes on 3,065 Posts
It is very important that you consider/inspect the condition of the trap and drain line connection in the wall before attempting to replace the entire trap. That looks like older plumbing and removing the P trap from the wall will not be an easy task.
Old 03-12-22, 03:43 PM
XSleeper's Avatar
Yeah, could open a can of worms. If one piece broke off, the rest is probably in the same shape.
