Laundry drain overflowing (only with hot water)
Old 04-05-22, 06:36 AM
D
My washer drain pipe started to do something strange. It began overflowing, but this only happens when we run a hot load. We run cold loads and the water drains fine. When it is hot water, the water doesn't go down fast enough and starts to overflow and make a mess. I think it's strange that cold water works fine down the drain, but not hot. I'm no expert though.
Any ideas? I'm assuming I just need to get the drain cleaned out. The house is 50 years old.
Old 04-05-22, 06:55 AM
P
Received 1,769 Upvotes on 1,582 Posts
Yes, start by clearing the drain and make sure it is working properly.
CasualJoe voted this post useful.
Old 04-05-22, 08:19 AM
Z
Received 93 Upvotes on 85 Posts
Hi detrog –
I don’t see how water temperature could make any difference. Could it be that your hot loads are larger and so you are using more water? I know on my machine the water usage is determined and varied based on load size. I think your hot/cold comparison would only make sense if the load sizes were the same. At least I think so.
So if you are dumping more water from “hot” loads, that may take you over the threshold and you experience the overflow.
Just a thought.
Old 04-05-22, 09:00 AM
Received 259 Upvotes on 232 Posts
Yes the first thing I would do is get the drain cleaned.
As to the hot and cold issue the only thing I can think of is that the hot water is heating up the pump vanes making a better seal and therefore pumping out more water.
But this is definitely a shot in the dark!!!
Old 04-05-22, 11:39 AM
B
Received 235 Upvotes on 208 Posts
I would think you might need a higher and/or larger id drain pipe, assuming the current one is not blocked.
