Can I install fittings on this pipe with a propane torch
Old 05-09-22, 09:30 PM
E
Received 3 Upvotes on 3 Posts
I need to cut this pipe at the red circle and solder in a water filter. The pipe is pretty stout although I don't have an actual measure of the sidewall, it doesn't flex at all. My father in law who is pretty handy told me that the fittings on their currently were done with an ox-acetylene torch and a high silver solder. I just have a propane torch is that good enough to solder on some fittings. We don't get earthquakes, nobody is going to bump into it, I don't care if its not as strong as the other joints as long as it doesn't leak.
Old 05-09-22, 11:59 PM
Marq1's Avatar
Received 1,105 Upvotes on 1,005 Posts
Hard to tell from the picture but if it's a copper pipe a regular propane torch will work fine, MAP gas a little better but both work.
Oxy Acetylene torches are for cutting metal, they would never be used for soldering copper pipes.
Norm201 voted this post useful.
Old 05-10-22, 01:18 AM
Received 3,422 Upvotes on 3,068 Posts
Using a plumbing solder with a higher than normal amount of silver will yield a stronger job.
Old 05-10-22, 04:55 AM
P
Received 1,769 Upvotes on 1,582 Posts
I would not install the filter there. You should mount the filter vertically. I would cut into the vertical part of the pipe after the shutoff valve (does it work???) then install piping to route to your filter mounted vertically to the wall.
If you don't mount the filter vertically changing filters is a major mess. If mounted vertically you simply unscrew the housing and only a small amount of water spills out. If mounted horizontally or upside down then then whole filter housing will dump when you unscrew it. Worst is that the dirt and sediment will also spill out making a mess.
Old 05-10-22, 05:31 AM
Marq1's Avatar
Good point regarding location, depends on the type of filter being installed. A whole house type filer would need to be horizontal with room for housing removal, dont want to remove that in a vertical position.
Old 05-11-22, 10:34 AM
Z
Received 367 Upvotes on 327 Posts
Standard plumbing solder (lead free) is acceptable and will provide a strong enough joint. For residential plumbing, failed joints have nothing to do with the solder, but the preparation. A half-decent solder joint should last 50-100 years without a problem.
There are probably industrial systems that require stronger joints or specially formulated solder, but certainly not worth the time/hassle for standard plumbing.
