sump pump cord splicimg
can we cut the male plug of a sump pump and just hard wire it.
thank you
thank you
Typically this is against the electrical code (NEC). It needs to be plugged in, and cutting the plug voids the UL listing.
In most locales, a GFI circuit is required, though some areas have exceptions. Some will also 'miss' that requirement to prevent false trips on a sump pump.
