I need to bring the vent for this kitchen sink to the right of this window. All my vents are 2”, but I could reduce down this portion to pass through the 2x4 studs or there is a 8” metal purlin directly behind the 4 studs on the right that I may be able to drill through. Should I drill/notch all the studs or try going through the purlin? Any suggestions?
code is IPC.
You can downsize to 1.5" vent for the kitchen sink. That'll help a bit with notching. And getting it as much behind the triple stud would be best. It looks like you have probably close to 1.5", so might only need to notch 3/4" or so - which would be much better than a 1.75" hole!
Hi All, is there a correct way to turn a system on at this BFP?
Thanks
Geo🇺🇸
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/56d2a2ba_c6b8_444a_a37f_b8f50005e928_d1ab20e25e16ffe642c4c4cb628faec47d830902.jpeg[/img]
Getting ready to start running vent pipes for our new construction home. Appreciate any suggestions on our planned layout?
Green line is our planned route with 2” and exiting Through side gable wall (no vented soffit)
Red line I would LIKE to connect and exit with the bathrooms, but thinking the length may not be up to code or work?
Thanks for any help.
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/771x800/e610d25f_36dd_42b3_baf9_c0661905a551_5f19d04ef3f7cf2266a65f64a0e3fdbee25a99cb.jpeg[/img]
