Back flow preventer
is there a correct way to turn a system on at this BFP
Both valves are open. The bottom one is plugged so nothing will come out. Unless there is a pipe behind it that comes out of the wall, that back flow preventer is doing nothing.
I would expect the supply to be at the side and the output at the bottom. Where is the supply coming from?
Is the black pipe going to the sprinkler system? If so, that should be on the output (with a drain valve teed in.)
The two small test ports can be closed with a screwdriver. Closed when the slot is at 90* to the output port.
There is a tee below the lower valve so there must be a pipe directly behind it we can't see.
There should be another shutoff valve inside in a warm zone feeding this.
2john02458
voted this post useful.
With most of these installations.... it's anything goes. No plumber involved.
Geeze, my question was is there a sequence as to which valve is opened first, supply or output to the system.
Geo🇺🇸
Geo🇺🇸
I don't think it makes any difference.
I usually open my supply valve first (because it is inside the basement near the meter.) I leave the outside supply valve always open. (It has a small handle and is very difficult to turn. Also guarantees that the pipe will be blown out back to the inside drain when winterizing.) Then I open the output valve at the back flow. A small amount of water spurts out of the top of the back flow until it is pressurized. (That's normal.)
