Angle stop: repairable? or replace?
Old 07-04-22, 08:08 AM
C
Received 22 Upvotes on 19 Posts
Happy 4th, everyone!
Working on a condo apartment to refit it for another occupant, and need to replace the vanity in the bathroom. I went to turn water off and the angle stops were seized; i got them to turn eventually but the hot water doesn't turn off water flow at the sink. I'm pretty sure i saw bits of the packing seal run down the drain in the water flow.
Can angle stops be rebuilt, or best to replace them?
Old 07-04-22, 08:45 AM
XSleeper's Avatar
Received 1,710 Upvotes on 1,534 Posts
Quarter turn valves are better quality and under $10 so personally, i replace them.
CasualJoe voted this post useful.
Old 07-04-22, 09:42 AM
P
Received 1,764 Upvotes on 1,577 Posts
Many of the stop valves use easily replaceable washers and can be rebuilt easily.
Old 07-04-22, 09:16 PM
C
Thanks for replies- i'll check into availability of replacement parts vs. R&R install.
Old 07-09-22, 05:41 AM
A
Received 250 Upvotes on 230 Posts
...if the screw that holds the washer on the valve stem breaks in the middle from having corroded somewhat over the years ...
(You finish the story.)
Old 07-09-22, 07:15 AM
C
Decided to go with a replacement. The old valves are compression fittings, and rather than source specific parts to rebuild the old, or buy an inventory of many parts to make sure to get the job done, i figured i'd cross go/collect $200 right away.
The annoyance is, the apartment bldg requires 48 hours notice to turn the water off. Having to work with their maintenance staff is adding layers of grief to what should be an easy task.
