Drain and Fitting questions
Old 08-23-22, 10:54 AM
E
In the picture there are two 2-in drain lines that I have a question about. The drain on the bottom has a bathroom and a kitchen on the first floor that drains into it. The drain on the top was probably added to accommodate a washer dryer.
Occasionally we smell sewer gas and assume it is from the top drain line and having the p trap right up against the sanitary tee. There's only one p-trap on the washer dryer drain. The standpipe is about 6 feet to the right.
right
Question 1: Is the current setup remotely code?
Question 2: how can I change this to make it to code with what you see in the picture?
Old 08-23-22, 11:22 AM
P
Received 1,772 Upvotes on 1,584 Posts
1. No
2. Relocate the right hand pipe's trap.
Old 08-24-22, 08:15 AM
E
Awesome! That makes sense. The short length between the ptrap and sanitary tee is causing siphoning?
Question #3. Can that trap arm be turned into a horizontal drain where vertical drains can be added? Would that be acceptable in terms of code?
Old 08-24-22, 09:52 AM
P
Several problems with a trap in that location. Yes, the lack of horizontal run can cause siphoning. Also the long vertical run before the trap get the water moving very fast and it can shoot right through the trap without collecting a pool of water to stop sewer gas.
That tie in to the vertical line could be used for other purposes if installed according to code. The big thing to look into is the venting.
Old 08-28-22, 01:17 PM
E
That's very helpful! Can an air admittance valve be used for venting purposes on that horizontal run? The drain would be for a clothes washer only.
Thank you!
