rid of copper green corrosion
Old 09-02-22, 11:11 AM
sgull's Avatar
Received 11 Upvotes on 10 Posts
Inquiring here how might be an effective/efficient method to rid this coil of copper tubing of the green corrosion stuff.
Old 09-02-22, 02:04 PM
Marq1's Avatar
Received 1,105 Upvotes on 1,005 Posts
It's a normal condition with copper, the coating is a natural result of oxidation, not any cause for concern.
People pay big bucks for "patina" need to love it!
Old 09-02-22, 02:08 PM
sgull's Avatar
Ok but I just wanted to be able to clean it off make it look nicer and more desirable for offering up for sale, and just in general.
Old 09-02-22, 03:19 PM
P
Received 1,769 Upvotes on 1,582 Posts
Use some very fine grit sandpaper or a Scotch-Brite pad to mechanically remove it.
Old 09-02-22, 03:34 PM
Received 3,422 Upvotes on 3,068 Posts
You could make a polishing paste of distilled vinegar, a little salt and a little flour.
Put the paste on the copper pipe and remove with a towel or sponge.
Not matter what you do it will be labor intensive.
You can probably make more money scrapping the copper.
Old 09-02-22, 04:31 PM
XSleeper's Avatar
Received 1,718 Upvotes on 1,542 Posts
Lemon juice and salt or baking soda also works. The Scotchbrite pad will shine it up but will give you a real workout doing that much. I don't think I'd spend my time doing it, but you asked.
Old 09-02-22, 09:54 PM
sgull's Avatar
Thanks for the replies. I was hoping for maybe a lazier method like being able to drop the whole coil into a tub of some solution and have it soak until the corrosion loosens enough just to rinse off
