Go Back  DoItYourself.com Community Forums > Plumbing, Piping, Water Heating, Wells, Air & Water Filtration and Conditioning > Plumbing and Piping
Reload this Page >
Water stain on ceiling looks like, Is this a leak and should we be worried?
Old 10-08-22, 09:34 PM
This is the ceiling in our garage, we’ve just moved to this house for two months. I must admit I’ve not looked at the ceiling there often, but today when I decided to inspect our sewage line in the garage I found out that around this line, which should be the one for our shower, has some kind of stain ring around it (please see the picture. )
wondering if we should be concerned? It’s not wet to the touch though. So might be something other than leak that causes it? Although I’m not sure what else could cause this.
Old 10-09-22, 02:08 AM
Received 740 Upvotes on 646 Posts
It kind of looks like an old leak that was painted over with latex without using a stain hiding primer.
I'd either clean up the pipe T or paint over it and then see if new leak evidence presents itself.
Norm201 voted this post useful.
Old 10-10-22, 01:51 AM
Oh thanks so much!
Will definitely try that.
Old 10-11-22, 11:12 AM
Z
Received 366 Upvotes on 326 Posts
I also like the trick of adding some pencil marks to show the edges of the current stain. In a few weeks, check back. If it's an old leak, the stains will not have moved.
jeweler voted this post useful.
Old 10-11-22, 12:39 PM
Received 3,417 Upvotes on 3,064 Posts
It was definitely water as you can see the water marks on the tee.
There could be many reasons for the water there. It could have been a one time thing.
Typically if it was a leak and you used that shower... it would get worse.
I'd expect to see more water dripping down the same tee..... probably onto the floor.
If that happens the shower drain is leaking.
Looks like old iron pipe and plaster which means old house and old plumbing.
