Occasional leak under laundry cabinet
Old 12-14-22, 03:41 PM
longbid's Avatar
Had a new washer/dryer combo installed with a new laundry tub by a "professional plumber" a few years ago.Every now and then I have a leak under the cabinet.No rhyme or reason why.I have disassembled and reconnected the strainer and pvc piping.Everything is done correctly as far I can see.I can run hot water for 5-6 minutes and surprise surprise no leaks seen or on my paper towel.I am flabbergasted and perplexed as to why.Any ideas or tips?
Thanks to all who can suggest a solution and for your time and concern
Old 12-14-22, 03:51 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
You had a new laundry tub installed but the leak is under the cabinet ?
What cabinet ?
longbid voted this post useful.
Old 12-15-22, 05:11 AM
P
Received 1,769 Upvotes on 1,582 Posts
Where is the leak coming from? Pictures of your plumbing would help since we have no idea what you have.
Old 12-15-22, 05:17 AM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
Most likely it's the drain piping slightly off plumb. You might want to loosen the P trap and related fittings and then relieve any possible strain that might be present. Then re-align and hand tighten (firm, a wrench should not be needed) all slip nuts.
Old 12-15-22, 07:45 AM
longbid's Avatar
Thanks to all who replied.The cabinet is the under laundry tub itself.
I will check the plumb for 1/4 inch per foot.
Like I stated it was done by a "professional".
Old 12-15-22, 10:07 AM
Z
Received 367 Upvotes on 327 Posts
I agree that it's likely the pvc trap. As they heat/cool, they sometimes have random dripping issues. It may become worse when the washing machine dumps all the water into the laundry tub. Since it's plastic too, it can bend a bit due to the weight of the water, and cause a drip.
Best solution is to replace the plastic washer that connect the trap to the tub, and the 2 washers that are on the trap. I've run into traps that just won't seal properly until the washers were replaced, even though there didn't appear to be any defect on the washers.
Norm201 voted this post useful.
