Replace cast iron sanitary tee with ABS?
Old 01-07-23, 03:52 PM
D
Greetings. I need to replace a cast iron (CI) sanitary tee that is leaking at the horizontal line. Can I replace it with an ABS tee? In the picture working up, it's CI coming out of the floor, a CI cleanout, the CI tee, a CI reducer, then ABS. The horizontal line is ABS threaded into the tee, going to the washer standpipe and a vent. Is there any reason I can't use ABS for everything, and connect it to the floor line with a no hub fitting? Any reason I should stick with CI?
Thanks!
Old 01-07-23, 04:30 PM
C
Received 107 Upvotes on 86 Posts
Replace away, especially since it's all just coupled together. Just make sure the ABS vertical is well supported when you remove all the stuff below it so it doesn't shift downward and stress upper connections.
desert_rnr voted this post useful.
Old 01-08-23, 10:19 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
I think I'd replace all the cast iron; the cleanout, the san tee and the reducing fitting. Replace it all with ABS. I don't know why, but many areas, including where I live, don't sell ABS any longer, but ABS is clearly available to be ordered.
Old 01-09-23, 07:12 AM
D
Thanks for the responses, and the advice to support the ABS vertical!
Old 01-14-23, 12:27 PM
D
With very few exceptions, all of the fittings I find are all hubbed. When connecting hub to hub (the cleanout to the sanitary tee, for example), I assume a short piece of pipe is used to join them? This is what I do with sprinkler/PVC, at least.
Old 01-14-23, 12:52 PM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
Yes... try to make that short pipe as long as you reasonably can so that you can see some pipe between the two hubs. I would imagine you'd also want a short piece of pipe below your bottom hub for your shielded Fernco coupler, so that you are coupling straight pipe to straight pipe.
Be sure you are using either ABS or all purpose glue.
Old 01-14-23, 01:18 PM
D
Thanks XSleeper. "try to make that short pipe as long as you reasonably can" - is that just to make sure the pipe is fully seated in the hub on either side?
Old 01-14-23, 01:31 PM
XSleeper's Avatar
Exactly.
