Are these fitting from my toilet correct?
Old 02-28-23, 04:35 PM
P
The first picture is the drain from the toilet going down vertically, itís 3Ē abs to main drain. Iím wondering if the fitting used to vent the drain is correct (looks like a sanitary tee connecting to 2" vent pipe).
The second picture is a little down the line where it connects to main drain, should the elbow in the picture be a regular or a long sweep one since its making a horizontal to vertical connection(or it doesn't matter which)?
Thanks
Toilet to drain
Old 02-28-23, 05:30 PM
Received 3,416 Upvotes on 3,063 Posts
If the black pipe in the top picture is the toilet line..... the vent is incorrect.
It cannot be a straight tee at that point or it could become clogged.
I'm not sure on the bottom picture but it's always better to use a wider/longer sweep.
Old 02-28-23, 06:17 PM
P
Right now the toilet has a sanity tee like this:
would one of these work better:
