Dip tube replacement
Old 07-11-01, 04:32 AM
sorrelmb
Question
How is a dip tube replaced? How difficult is the job to do on a State residential gas water heater? Should the sacrificial anode be replaced at the same time? Heater is 7 years old, on county water system. I am a victim of the disintegrating Perfection brand dip tubes.
Old 07-11-01, 06:45 AM
abNORMal's Avatar
Not too difficult.
Flush the crud out of the bottom of the tank first.
(i.e., Hook a hose to the spigot at the bottom of the tank, run it outside or to a drain, open the spigot and let run for a bit.)
Shut off the gas and cold water supply.
Open a faucet to relieve pressure.
Disconnect supply (probably cut if copper; probably disconnect union if galvanized).
Unscrew dip tube and remove.
Insert new dip tube and tighten down (use teflon tape).
After 7 years the sacrificial anode will probably need replacing. Should unscrew from the top.
Reconnect supply.
Close previously opened faucet.
Water supply on - check for leaks.
Gas on; pilot lit.
Run a tub faucet to clear crud.
Might as well have a bath, you're all sweaty by now
