re-attaching Bath tub drain latch
Old 07-11-01, 05:18 PM
Guest
Our drain stopper in our bath tub has come undone.The water can not drain. How do you get into the drain and hook it back up? Any help on this would be greatly appreciated! Thanks,
Kim
Old 07-11-01, 06:14 PM
Mike Swearingen's Avatar
Cool
Unscrew the two bolts on the overflow plate, and pull out the upper part of the drain assembly. Fish the lower part with the drain plug that has become detached out with a piece of stiff wire (coathanger?).
Repair or replace the drain stopper assembly and re-install it.
Good Luck!
