toilet trouble
Old 07-12-01, 08:04 PM
Guest
Question
my toilet was working fine, now all of the sudden it will not flush(stopped up) and i hear air like sounds coming from the rear of my toilet at the floor .
help please
Old 07-13-01, 05:41 PM
Mike Swearingen's Avatar
Cool
It could be a clog in the drain line or in the toilet itself.
A toilet has its own built-in trap, so start there.
Get a crank toilet auger, feed the auger up into the trap, and crank away.
If whatever is clogging it cannot be dislodged from the bowl side, you will have to pull the toilet and try to dislodge it from the underneath side (and snake the drain while the toilet is up.
See "Repair/Fix-It" above for illustrated how-to (Plumbing section).
Good luck!
HTML code is On
