Washer valve box too low
Old 05-15-24, 07:16 AM
A
Bought a new front-loading washer on a pedestal. It is hard to reach behind to turn the water on/off with each wash, which I always do. Presently using small step stool to reach over & behind. Is there an easier way? Special handles? I don't want to have to move the valve box higher up the wall.
Top Answer
05-15-24, 04:17 PM
RocketJSquirrel's Avatar
RocketJSquirrel
RocketJSquirrel is offline
Received 59 Upvotes on 51 Posts
Turning the water off between loads seems unnecessary to me. In all my many decades of life, I have never done that and never had a problem.
If you're afraid a rubber water hose might burst, get a pair of the metal-reinforced ones. They'll probably outlive you.
https://www.acehardware.com/departme.../hoses/4599239
Old 05-15-24, 07:27 AM
B
Received 314 Upvotes on 277 Posts
Can you get longer hoses and move machine to either side of valves?
Old 05-15-24, 07:37 AM
A
No, wish I could, thank you. Space is limited to room for only washer & dryer
Old 05-15-24, 08:02 AM
P
Received 2,270 Upvotes on 2,022 Posts
You can extend the handles if you feel creative and have some metal working skills. You can recreate how a steering wheel in a car works. A handle at the top, then a shaft and a universal joint connecting to your valve handle. A bit Rube Goldberg but it can work.
There is a washer valve that has a single lever to shut off both hot and cold. You could attach a simple extension lever to the handle and pull it up or down to control the water.
There are also automatic valve control boxes you can install.
Old 05-15-24, 04:17 PM
sdodder, XSleeper voted this post useful.
