Issues With Dry Well
Old 05-25-24, 08:15 AM
T
Received 1 Upvote on 1 Post
I have a small trench drain in front of attached garage that about a year ago I had a contractor connect a dry well to. The issue is I'm still getting flooded everytime theres heavy rains. Even 20 minutes of heavy rain will be enough for the trench drain to overflow I recently had a plumber come out with a roto router to check for clogs and he didn't find anything.
As luck would have it I stumbled upon an older video I took of my contractor installing the dry well and perhaps I'm going crazy but it appears the drainage line connects to the dry well at the bottom of the tank. Could anyone view the video I posted on Youtube and confirm? Is this akin to trying to fill a bathtub by pouring in water from the bottom of the tub? Ie its impossible to fill the tank and my only solution is to dig up the drywell and bury it a few feet deeper so the drainage line connects to the top?
As you can see from my photos I get quite a bit of water in this recessed area as the rest of my house including my driveway is more elevated and pitches downwards so water from my driveway, front of the house, yard finds itself in this area.
Many thanks for the help!
https://www.youtube.com/shorts/LPE-ODVJumw
Old 05-25-24, 08:17 AM
T
Apologies for some reason my images aren't attaching properly so posting more photos here for reference
https://imgur.com/a/Ji49JsV
Old 05-26-24, 07:51 AM
A
Received 287 Upvotes on 262 Posts
It is not conventional to drain water into a dry well by piping into its bottom but that might be needed if the entering pipe has to be well below tghe ground surface for example below the frost line.
If a dry well overflows and the water returns to the house foundation, then you need to do or add add something else to get rid of the water. Maybe a sump pump. Maybe regrade the land so the overflow goes away from the house. You finish the story.
Old 05-26-24, 09:27 AM
P
Received 2,265 Upvotes on 2,018 Posts
A major problem with dry wells and French drains are they can fill up. It is entirely possible that your dry well is simply filling up and without anywhere for the water to go everything fills up, including your driveway. If at all possible I would drain your driveway to daylight but that requires someplace downhill to send the water.
Old 05-26-24, 10:56 AM
Received 4,099 Upvotes on 3,682 Posts
The alternative is to pump it.
