Tub Drain
Old 07-17-01, 10:58 AM
Guest
I have stripped the drywall and removed the old tub in my bathroom. No problem. The tub drain P-trap has an approx. 8" long galvanized extension pipe. I cannot get the overflow/tub drain extension out of the 8" long pipe. It should be a slip-fit. Any suggestions? I have been applying penetrating oil.
Old 07-17-01, 07:30 PM
Mike Swearingen's Avatar
If you have room, use a pipe wrench with a "cheater pipe" extension on the handle for leverage. A cheater pipe is just a piece of galvanized pipe large enough to fit over the end of the pipe wrench handle.
THAT should break it loose.
Good luck!
(Ex-TX here, Gladewater in the NE).
