Go Back  DoItYourself.com Community Forums > Plumbing, Piping, Water Heating, Wells, Air & Water Filtration and Conditioning > Plumbing and Piping
Reload this Page >
How to split kitchen cold water outlet into three (faucet, water filter, fridge?
Old 06-20-24, 11:44 AM
D
Received 1 Upvote on 1 Post
I have one copper pipe with one shut-off valve underneath my kitchen sink.
How can I split it into three?
- water filter (comes with a 1/4" brass tee: https://cdn.aquasana.com/assets/AQ-5...00_Install.pdf)
- fridge icemaker
- main faucet
Old 06-20-24, 02:37 PM
Received 59 Upvotes on 51 Posts
I would first split it in two: main faucet and water filter. Then I'd split the water filter output in two: drinking water spigot and fridge. Then your ice will also be filtered.
Old 06-20-24, 03:23 PM
D
Interesting idea. My fridge does have a filter as well. Not sure whether I can bypass the fridge filter. But like the idea here.
Old 06-20-24, 04:06 PM
XSleeper's Avatar
Received 1,973 Upvotes on 1,770 Posts
Install a tee onto your copper pipe, a short length of pipe, then a single inline quarter turn shutoff straight up to the sink and on the right or left side of the tee, a short length of pipe then a quarter turn 90 degree tee shutoff. Assuming you have a separate drinking water spigot on your sink.
Old 06-21-24, 11:10 AM
If the fridge has its own filter, no need to pass water through the under-sink filter.
Old 07-04-24, 02:31 PM
D
Assuming the tee needs to be soldered?
and then on filter side, ideally a T that splits into 2x 1/4"?
Are there such T's with 2x 1/4 outs?
https://www.homedepot.com/p/Everbilt-3-8-in-Compression-x-3-8-in-Compression-x-1-4-in-T-Fitting-EBTF3825/325842877
or
https://www.amazon.com/Compression-P...07QPBWJNT?th=1
it seems most of those valves split either to two 3/8 or one 1/4 and one 3/8
Old 07-11-24, 02:09 PM
D
ok, I ended up with this:
