toilet continious running
Old 07-18-01, 02:43 PM
Guest
After my toilet is flushed and the tank fills back up it still runs until I put about a glass of water in to the tack
Old 07-18-01, 04:15 PM
Mike Swearingen's Avatar
Cool
What type of toilet tank water inlet assembly do you have? Float ball or float cup?
If it is a float ball, bend the brass arm so that the ball is lower.
If it is a float cup type, pinch the clip on the side of the cup and slide it up slightly to raise the water level.
If neither of these help, replace the water inlet assembly with a Fluid Master float cup type.
Only about $7 bucks, and easy to install. Just follow the directions.
Good Luck!
