plumbing
Old 07-21-01, 04:06 PM
Guest
hello i have aseptic tank at my house when i run my washing machine the suds come up through my sink in the bath room i dont no if i have a clogged sewage pipe or i need my septic tank pumped als the water in my toliet bowl will drain out the toliet makes noise then water is gone please help me with my problem could you tell me cost of cleaning septic tank also thanks for your help you can reach me at jessi99@msn.com
Old 07-21-01, 05:08 PM
Mike Swearingen's Avatar
Cool
Things vary from place to place. Here in Northeastern NC, it costs $125 to have a septic tank pumped out.
I don't think that your septic tank is the problem here, though.
It sounds like a partially clogged drain line or vent pipe.
First, have someone go up on your roof to check all of the vent pipes for leaves and debris that may be clogging them.
Have them clean out all that they can reach, and flush the drain/waste/vent pipe with a water hose sprayer.
If that doesn't help, you need to snake (with a metal plumber's snake) the drain lines.
Good Luck!
