Replacing an
Old 07-28-01, 06:34 AM
Guest
Whenever my clothes washer is in the discharge mode, water flows up over the discharge pipe and runs on the floor. It seems very little of the water is actually flowing through the discharge pipe. I've checked the iron pipe (18" high from the point it meets the "S" trap) and there is no obstruction(s). A professional plumber when clearing my main drain to the street suggested I replace the iron "S trap" with (I believe he said "U" trap). I have removed the 18" section of the washer discharge pipe, and the "S" trap does appear to have gunk in it, I've removed as much as possible, unfortunately, I cannot get the drain plug to budge. I'd like to replace the iron and go with PCV. Is this a good idea? If so, what size piping and configurations are normally used? Do you think replacing the S trap will allow water to flow like it should (assuming no other obstructions are in the line)? Thanks in advance for any assistance/advice you can provide!
Old 07-28-01, 04:09 PM
Mike Swearingen's Avatar
Cool
Replace the washer standpipe with 1.5" PVC and a U-shaped "P" trap.
Good Luck!
