Replacing element - Help
Old 07-29-01, 03:12 PM
Guest
Question
I'm replacing a water heater element, the bolt on kind, and I can't get it to seal up watertight. I'm using new gaskets. Is there some product or technique that I can use to make this work?
Thanks!
Old 07-29-01, 06:51 PM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
I haven't done an element in quite a while (usually my tanks fail before I need to do an element), but I would think ordinary gasket sealant would work fine. Check your local auto parts store for one that is suitable for water pump gaskets - same basic function, seal hot water areas. (Permatex or other brand). Be sure to follow the directs on curing time before you turn your water back on.
