Replacing steam heat plumbing
Old 08-02-01, 01:33 PM
Guest
We have an 80 year old home with boiler/radiator heating. We would like to remodel the basement and replace the old low hanging iron water lines with copper lines so that we can finish off the ceiling. Two questions: What size pipe should we use and how do you attach the copper tubing to the risers?
Thanks.
Old 08-02-01, 03:09 PM
It seems like you could use the same size. A great way to attach to copper is with a Dialectric union. Make sure the union is accessible.
Good Luck
Old 08-02-01, 05:42 PM
Mike Swearingen's Avatar
Cool
You should use same-size heavy duty copper pipe (Type K) for this application, I believe. Double-check with your Building Inspection Department for local Plumbing Code.
This is a di-electric union that John mentioned that you should use between two different types of metal to prevent electrolysis corrosion:
Courtesy of ATOZPLUMBING
Good Luck!
