Hot water heater noise
Old 08-14-01, 09:51 PM
Guest
Our 8 year old gas water heater is now making a "popping" noise like the sound of heavy rain drops. This noise seems to be more obvious after using the hot water. Any suggestions on where to start?
Old 08-15-01, 12:28 AM
Mike Swearingen's Avatar
Cool
Attach a water hose to the drain spigot at the bottom of the heater and drain out the sediment that is most likely causing the popping.
Good luck!
Old 08-15-01, 03:16 AM
mrmojo's Avatar
noise problem also but sounds like a dog yowling any thoughts?thanks
Old 08-15-01, 05:12 AM
Sounds like an excess pressure problem or a faulty toilet tank water inlet valve.
Where does the noise seem to be coming from?
