toilet flush problem
Old 08-16-01, 09:28 AM
Guest
Question
I've got a toilet that has a couple of problems.
First, I have to hold the handle down for a good few seconds (sometimes the duration of the flush) to get a good flush. Secondly, the flush itself is quite weak. The sink & shower pressure in the same bathroom have good pressure.
Any ideas?
Thanks.
Old 08-16-01, 03:08 PM
With toilets you get what you pay for so if it is new and a cheap one (under 300 dollars roughly) that is where I would suspect. If it is old maybe it needs replaced. Possible it has something stuck in it. in which case you need to use a snake or closet auger.
Good Luck
