Washing Machine draining causes toliet problem
Old 08-25-01, 01:25 PM
Guest
Earlier today my washing machine drain caused my downstairs toliet to overflow. I cleaned up water, plunged but now water level in downstairs toliet water level in bowl is very low. I am affraid to run another load. Please help this working mom, who does laundry leftovers on Saturday for family of 4.
Thanks,
Old 08-25-01, 04:11 PM
Mike Swearingen's Avatar
Cool
Sounds like you may have a clog in the main drain line, and the washing machine filled up the line, causing the toilet to overflow.
You need to snake the line with a rented plumber's snake through a clean out plug.
If that doesn't do it, you may need a roto-rooter job, if you have old drain pipes.
Good Luck!
