Can not remove shower valve stem assembly
Old 08-27-01, 09:12 AM
Guest
Question
Hi and thank you for your help.
I have an old shower (20-30 years old?) that leaks at the showerhead and in one of the handles. I am having great difficulty in removing the hot and cold valve/stem assemblies for replacement. Once the handles are removed and the valve/stem assemblies are exposed, I can not seem to remove them with a wrench. It feels like I could rip/twist out the copper tube the assembly is screwed into if I turn to hard.
I have turned off the water and opened the sink faucet to remove pressure but no luck. I am an obvious novice so any assistance would be greatly appreciated.
Thank you,
JMazz
Old 08-27-01, 11:33 AM
Plumber2000's Avatar
Try some stem sockets like these one's they should be able to remove from there.
Difficulty:
