Outdoor faucet
Old 08-28-01, 07:56 AM
Guest
Question
Water is leaking from about 8 inches above the outdoor faucet (single handle). It is coming from up under the plywood which is under the vinyl siding. It's a cracked pvc pipe or someting. Our money is tight! How do my husband and I go about getting under there to even see the source of the leak? It's a light spray, not a big, big leak, but it still is causing a wet area of plywood and ground under the faucet. HELP!! Our house is 4 years old and we are not on a warranty any more!
Old 08-28-01, 08:03 AM
Plumber2000's Avatar
Is there a inside wall you can open up? If so access it through it.
Old 08-28-01, 08:11 AM
Guest
Outdoor facet
There must be one, I hate to say this, but I think the inside wall may be where my tub/shower is in the bathroom. It is a whole bathtub/shower unit made of fiberglass type stuff. Help!
Old 08-28-01, 08:27 AM
If you can not find any other way of getting into that wall then you may have no choice but to access through the outside.
Goodluck.
