Faucet hiccup
Old 09-07-01, 02:13 AM
Guest
I have a problem with my kitchen faucet that I cannot tell if it is in the faucet or the pipes. Whenever I turn on the hot or cold water, the water comes out strong but then "hiccups" and turns to a trickle. If you turn the water off and right back on again it will work just fine. If you wait a minute and turn the water on you have the same problem. Anybody ever seen this problem before?
Old 09-07-01, 04:27 AM
Mike Swearingen's Avatar
Cool
You apparently have a problem in the faucet itself.
What type of faucet is it?
You can look in the Plumbing section for illustrated info in "Repair/Fix-It" above.
Good luck! Mike
